Here's a link to the door handle parts view.
http://www.********************************************.com/porsche-parts/986-97-04/804-20.php
Make sure you disconnect the battery before you remove the door panel to avoid any air bag accidents. Quote from Bentley manual door panel removal section, "Wait one minute after disconnecting battery before working in vicinity of airbag."
And I am pretty sure that you will need the radio code also if you disconnect the battery. I don't worry about this since my car came with an after market radio.
Let us know what you find, as our cars get older, more of us will run into these same issues.
3X Water Pump, Clear side markers, Crios Mod, Front engine mount, Flywheel, clutch, RMS, AOS, MAF, serpentine belt, power brake vacuum line, battery, 2X CV boots, Fuel filter, Oil filler tube, 3X ignition switch, 90K service, gas cap
