Originally Posted by Dale_K
On my car, a 2000 S, the washer didn't work when I bought it and fluid leaked below the car whenever I tried to use it after filling the tank. Turned out there was a hose disconnected. I had to pull the left front wheel well liner and the detached hose was pretty obvious. I've read it's a pretty common issue.
Thanks for the insight. Unfortunately - the washer fluid is full when I pop the hood trunk and check- so I dont believe its a loose or disconnected hose. I will definitely check though.
