Old 04-13-2011, 07:18 PM   #31
schoir
Originally Posted by Fastass986
I Mean The Right Side Visor Sensor Cause I Got The Light To Come On Ebrake, The Top Went Back Down And Then I Tried To Put Up 3 Hours Later After Driving And Went To Put Top Up And It Stopped Half Way So No The Top Is Stuck Open, Nice Huh.....think I Need Sensor In Ebrake And Does The Sensor On Left Stop Motor From Working And Maybe Motor????
If your e-brake light goes on, there is no need to replace the e-brake microswitch as you can always tell when it's not working: the e-brake light will not go on and you will not get power to the electric motor.
There is no sensor in either the left or the right visor, but there are two microswitches inside the latch receptacle assembly.
If you don't have a dead spot on the electric motor, the intermittent operation is probably being caused by the microswitch inside the right side of the latch assembly. That one also supplies power to the electric motor. You have to check that one closely for hairline cracks because heat/cold will sometimes cause the connection to be made/broken.
Regards, Maurice.
schoir is online now   Reply With Quote
