Originally Posted by coolbreeze551
I decided to have a quick look tonight at the engine. I wanted to get a look at the coolant tank and water pump and find the possible culprit.... Here are the highlights
1. Coolant reservoir isn't leaking (carpet is not wet, no puddle of coolant)
2. Dead cat near the water pump (pulled apart easy, dead for a while)
3. Coolant tank will not hold coolant, just drips out the bottom of the car near the middle.
Before I knew it it was getting dark and I didn't have time to take the bottom panel off the bottom of the car to get access to the leak. I am thinking that it is a hose that came off. Any ideas would be great on this one.
when you say "dead cat"... you mean "meow-meow?"
