Finally installed the strut bar braces
After reading some positive and neutral feedback on the strut bar braces, I finally went ahead with the schnell front and rear strut bar braces...
The front bar is quite massive at 30mm (I think) though the joints are alot smaller. The rear bar is quite slim.
After installing them, there is definitely quite an improvement in the handling, esp in the front. Not sure if it's because I have the M030 kit or my car's chassis is getting weaker after 10 years of rough roads. But the front feels tighter with less side to side bouncing. I now feel that the front suspension gets to do its job better. It also takes rough roads better now. Distinct improvement but not a dramatic improvement.
It has also helped on the windscreen shimmy alittle.
But the strange thing is that I now have occassional creaks coming from the frame of the roof. In the past it was totally silent and I only get squeaking noise from the rubber seal below the plastic window. If the structure is stiffer now, why would there be creaking from the roof ? I'm puzzled. Any ideas ?
