Old 04-08-2011, 05:01 PM   #2
clickman
Make sure you've got a big flat drain pan. There's a lot of oil in those suckers!
You'll need a cup wrench to get the filter housing off and then tightened, although I've never found one that works for me, and use a strap wrench to get it off (protecting the side of the filter housing) and just tighten the new one by hand. Works for me; no leaks.
You need a new crush ring for under the drain plug. Do you have the proper 8mm Allen wrench for the drain plug? I replaced my stripped aluminum stock plug with the LN Eng magnetic plug.
Make sure you let it drain thoroughly. I jack my car up on one side to get access, but when it's draining I let it down.
There's a whole big debate on oil, and it has steered me away from Mobil1. I ran it for 4 years, but my last fill (after flushing) was with Castrol Syntec 5W-40. I would use Syntec 10W-40, but we can't get it in Canada. Apparently any 30W is too light.
Don't forget to cut open your old filter element and check for debris!!
clickman is online now   Reply With Quote
