Alignment and/or air pressure.
Normally, the standard rear alignment will wear the inner 2/3's of the tire. The outer 1/3 barely sees any wear until you push the car hard in the corners and the camber changes to straighten up the tire so the outer 1/3 sees action.
If the alignment is off, then the car could be running mostly on the center 1/3 of the rear tire rather than on the inner 1/3 + center 1/3. This would tend to double the wear on the center 1/3.
If the air pressure is high, then the rears will wear more towards the middle as the air pressue will reduce pressure on the inner 1/3 of the tire and have the same effect as poor alignment.
Have a good alignment done and consider reducing the rear air pressure a few pounds.
Also, check the passenger rear for anything bent or worn like a wheel hub or suspension component.
