Old 03-16-2011, 10:47 AM   #4
thstone
Based on your posting, some of the wording is open to interpretation:
While the crankshaft bearings are clearly covered, its not clear whether "camshaft, bearings," means that the intermediate shaft and bearing is covered. Furthermore, because the crankshaft and the camshaft are mentioned by name, one would normally conclude that the intermidiate shaft was omitted on purpose.
Also, none of the engine seals are explicitly mentioned as being covered (RMS and/or cam cover leaks come to mind).
Based on confusing wording regarding the IMS and lack of coverage for the RMS, I'd suggest thinking twice about this warranty because its not likely to save you from the most likely catastrophic costs.
