Old 03-10-2011, 08:09 AM   #8
clickman
Originally Posted by surf40
Could somebody point me to where I can find more info on the 05 engine change that prohibits the IMS retrofit, and when that changed (mid 05 MY, or 06?)
05 was supposed to be the last year the bearing could be retrofitted, i.e. small enough to be pulled out without having to disassemble the engine.
But if you do a search on the subject, you'll find that the bigger bearing has also been found in 05's, and IIRC there's no easy way to determine which one it is.
When did Porsche change over to the bigger IMS?
