Old 03-08-2011, 06:28 PM   #27
schoir
Originally Posted by Andrew McD
Is it possible to remove the valve to see if it needs replacing? And if so what would I be looking for?
Thanks, A.
Andrew:
Yes, it can be removed... See the photo I attached in the previous post for what you end up with once it's completely removed.
If you go to the trouble of removing it, you may as well replace the O-rings.
Also inspect the rubber membrane immediately under the top portion of the assembly.
There is a photo of a defective one earlier in this thread.
BE VERY SURE to heed the cautions against overtorquing the bolts.
Regards, Maurice.
schoir is offline   Reply With Quote
