Old 03-07-2011, 11:41 AM   #2
insite
Originally Posted by The Radium King
i've read (ie, no ral expereince) that sometimes vehicles will stall with a lwfw, as the ecu anticipates a certain lag in rpm drop when the clutch is depressed. they way i read the initial description, it read like the stall happened when the clutch was depressed, not re-engaged ...
ah; i hear what you're saying now. the revs do drop very fast. in the older cars, if the idle valve is the least bit sticky, it won't always react in time to keep the engine from stalling. i think the e-gas cars don't have this problem so much as the early ones. byron's was e-gas.
i was working under the assumption that the engine died after the downshift was completed. byron?
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
