Old 03-04-2011, 10:47 AM   #6
PhilNotHill
Originally Posted by mikefocke
– Incorrect signal from MAF sensor
– Intake air system leaking
– Fuel pressure too low
– Volume supply of fuel pump too low
– Fuel injectors fouled
– Exhaust system leaking
Of those, fouled fuel injectors may be the cheapest/easiest fix. Sometimes adding Techron to your gas may solve the problem. Chevron gas comes with this additive already.
Otherwise a mechanic will have to clean (or replace- last resort) the injectors.
Good luck.
PhilNotHill is offline   Reply With Quote
