Old 02-28-2011, 09:47 AM   #5
insite
your car will run fine /w the supercharger. the car can handle the 4.5psi boost fairly well in the 2.5L. just do NOT go to a smaller SC pulley; overboost WILL kill the motor. also, get the car ALL the way up to operating temp before you drop the hammer.
that having been said:
1. Install; PDF Instructions (anything & everything)
#can't help you there
2. Tuning/ECU; Necessary? Price? Can I drive without it? How much better with it? Pros & Cons? Where to buy? (Evolution Motorsports, CA preffered; VF Engineering, GIAC USA, GMG)
#the car can actually adapt to the supercharger fairly well.
3. Flash Program; Available? Price? Where to buy?
#see #2 above
4. Injectors; Pros & Cons upgrading, required/necessary. Price? Part #s or Models? Where to buy?
#not necessary. the injectors on the 2.5L are the EXACT same part as those in the 3.4L carrera. plenty of flow.
5. Maintainance; SC Oil Changes? Replacement Belts/Parts?
#i'd go w/ the manufacturer's recommendations
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
