Old 02-21-2011, 10:05 AM   #16
schoir
Originally Posted by shlim8
Thanks for the advice. After I saw pictures of the broken bolts, I understand why ! I didn't even try to tighten the bolts on my current breather valve any more than a millimetre...
I had thought of changing the entire coolant expansion tank, it's still good but has yellowed to the point that I can't see the coolant level. But after reading the instructions on the replacement of the tank, I decided not to...
A wise idea not to replace the coolant tank unless it's leaking.
To get a better view of the coolant level through a somewhat opaque, yellowed tank, you can take the coolant cap off and put a flashlight vertically on the opening. That usually "clears things up".
Regards, Maurice.
schoir is offline   Reply With Quote
