Old 02-15-2011, 08:10 AM   #154
insite
Originally Posted by Paul
Thanks, any tricks or guidance on safely opening the plug housing so the pin can be inserted?
sure. this is for the OLDER '99 DME; the newer ones are a little bit different.
1) disconnect the harness from the DME
2) cut the zip tie and open the back of the socket cover
3) use a small screwdriver to remove the weather seal from around the socket
4) remove the phillips screw from the outside of the socket
5) push the far end of the socket down; it will rotate forward & out of the cover
6) pull the socket through the cover
you how have a totally exposed DME connector. the pins are removed / inserted from the back of the plug.
Where can we obtain the pins with the wires attached or did someone with correct pin tool remove one from a used harness?
i got mine from a fellow forum member; it had been removed from a used harness. i probably have some if you need one.
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
