Originally Posted by Paul
Nice job, could you elaborate on how you moved the pins on the DME harness?
sure. there's a tool that can be used to gently remove a pin from the harness at the DME. after that, it can simply be pushed into another slot.
i don't have the tool, though, so i bought a pin with a segment of wire attached to it. i pushed it into the correct 'new' slot, then clipped the wire & soldered it to the new one.
