Even though the system is “active”, you will not see any display until you connect up either the fourth stalk or some other type of control for the display. Only the early cars immediately got the outside temp display without the stalk.
Does anyone have a link to how the wiring should be done if I use a switch. I am just going to use one button and live with the fact that I can only scroll through the display "in one direction".
Thanks,
Lars
'03 986, Seal Gray, De-snorkled, Painted Calipers, Alu pedals, smoked side markers, Non-smoker kit, DIY Garage door opener, dyed top
