Originally Posted by Lobo1186
Well a veneer is good and all but honestly if I was to do that I should have started with lesser stock. Cherry isnt cheap compared to oak or something to that extent so I dont want to cover it up. The inside needs to just be moisture protected as the spanish cedar WILL cover all the inside.
Is there some kind of liner, plastic or otherwise, to protect the outer wood from the humidity of the inside? I am not sure a cedar lining would keep moisture from seeping through to the outer cabinet. Be a shame to have that happen after all your fine looking effort. Keep us posted on your progress and thanks for sharing.
AKL
'02, Arctic Silver/Graphite Gray, 2.7, TIP, 2nd cat delete, Charlie Chan muffler,de-ambered, Braille Battery, clear tailights, painted bumperettes, clear third brake light, M030 sway bars, F shock tower braces, clear rear deck, '03 side vents.  15mm spacers fore & aft.
