Old 01-17-2011, 11:54 AM   #3
insite
Originally Posted by Gilles
I had always assumed that you get the corner balance by fine tuning the height at each corner (@ the spring perches), not really by pre-loading the sway bars..
gilles -
you are correct, HOWEVER: when you adjuste the corners, you have added pre-load to the sway bars. the adjustable drop links are used to REMOVE the pre-load condition that's caused by corner balancing.
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
