Old 01-15-2011, 08:07 AM   #5
clickman
Originally Posted by nefarious986
the blue cable ( which I think controls the side to side motion ) is about 1/4" too short to drop in directly.
Taking the alignment tool off and pushing the shifter slightly to the left ( toward driver ) pushes the cable end attachment back enough so that blue cable can just drop in. Doing this though leaves the shifter slanted to the left instead of aligned in neutral.
This doesn't sound right. I think you need to have a pro look at the blue cable and maybe its attachment at the tranny. I don't know if you can adjust the length of the cable.
Did you have any shifter issues before the swap?
You may also need your motor mount done, which could possibly be affecting things, although you'd think it would affect both cables. Has it been done? What's the year / mileage of your car? S or non?
