Old 01-11-2011, 08:56 PM   #1
schoir
Originally Posted by 508421
HI and thanks for your comments / help , the problem does not seem to be coming from the door as the carpet below the door is bone dry , the moisture is only present around the area where the pedals are and is working its way toward the seat , i keep it as dry as possible to protect the electronics below the seat , maybe it stems from drainage ?? any further help / advice / instruction would be great , cheers.
Take a look at the following link for diagrams/locations of the drains in the front trunk for a possible cause to the water intrusion that you describe: http://sites.google.com/site/mikefocke2/drainsdiagram
The other possibility, as I mentioned in the earlier post below is that the water is leaking from the radiator core.
Regards, Maurice.
schoir is offline   Reply With Quote
