Old 01-06-2011, 03:59 PM   #1
clickman
Originally Posted by Fluellen
I wouldn't be so quick to condemn the dealership. It's quite possible that these two leaks are separate incidents.
If an engine leaks as much as you describe, chances are it's been neglected for a long time (not necessarily by you, I am sure there is a PO somewhere...) and likely has plenty of other things that are on the verge of failing. So this may just be unfortunate coincidence.
The OP said it was leaking just as bad after the "repair" as before.
Cam covers on the M96s can tend to weep; no big deal.
They missed whatever the real problem is.
clickman is online now   Reply With Quote
