Theoretically interesting, but practical experiences say otherwise. Byron is of the impression shrapnel from his grenadeing M96, complete with holes in the block, tore up the pump; but if that were the case, there is no way the engine continued to run for ten seconds after dispatching a rod through the block, or even two seconds for that matter.
mine ran for about fifteen seconds before it stalled out. it still turned over a couple more times with the starter before it locked. byron - how long did your motor continue to turn over after you started seeing smoke? i think i remember you stating that the entire process (from the INSTANT you noticed a potential problem) took several minutes. am i correct?
