Old 12-04-2010, 06:48 PM   #1
eightsandaces
Originally Posted by BassMD
Would you please explain in more detail how to disassemble the switch?
This is from memory, its in the bentley book mine is with the car, first you remove the plastic finish collar surround piece. You need something pointy to work with like a nail set. Then you will see a small dimple on the metal collar now exposed with the trim piece off, if memory is right you press the dimple and its a twist lock.
eightsandaces is offline   Reply With Quote
