Old 12-02-2010, 04:32 PM   #110
schoir
Originally Posted by insite
i really can't wait to drive it. it died in march of '08! been WAY too long. it takes me a good bit of restraint not to rush it......
one of the coolest things was watching the VarioRam properly actuate, proving all the wiring & vacuum routing works like a champ.
one odd thing: the low coolant light is flashing. i'm all topped up, the system is burped (heater routing too!), and the sensor is plugged in. small issue, really.....
Insite:
WAY TO (methodically) GO!
When you first get it on the road, make sure you get photos of your permagrin that are as good as the other photos you have posted!
For the coolant light flashing, is it possible that the float sensor (inside the tube in the coolant tank) is stuck in the down position and is thus sending an incorrect signal?
Also, don't forget that the "coolant level low" warning light can also flash to indicate a fault in the engine compartment blower fan, so check that out as well.
Regards, Maurice.
schoir is offline   Reply With Quote
