Old 11-30-2010, 01:32 PM   #25
insite
absolutely. it exits the top of the oil cooler, routes behind the starter, and exits from beneath the intake manifold on the passenger side. it connects directly to the coolant reservoir. nothing connects to the oil pump.
Originally Posted by schoir
Insite:
Did you happen to notice exactly where the rubber hose that starts at the top of the oil cooler (in your photo above) is routed?
Did your '99 motor have a metal nipple protruding from the top of the oil pump housing at the front of the engine, and was there a hose that ran from that nipple towards the rear of the engine, to the coolant reservoir or to a Tee with a connection from the hose that comes from the oil cooler and then goes to the coolant reservoir?
The reason I am asking is because a previous owner of my '98 engined Boxster just plugged the top of the oil cooler with a short piece of rubber hose and clamped in a bolt to seal it off. I haven't been able to find the correct routing of that hose from the top of the oil cooler.
Regards, Maurice.
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
