Old 11-30-2010, 01:24 PM   #24
schoir
Originally Posted by insite
another thing to deal with is the brake booster line. on the 996 manifold, it's on the wrong side. to deal with this, i cut off the hard line that runs up the firewall from under the car. it's possible to cut off the flexible section, exposing a barbed outlet.
to this, i attached some 16mm silicone vacuum hose that i routed underneath the manifold & up to the inlet. originally, i'd flipped the inlet upside down so it pointed downward instead of upward. it turns out that it won't clear my intake plumbing this way, so i put it back into its stock position.
oh yeah, i forgot to mention that the engine is in the car.......and that i've started it.
Insite:
Did you happen to notice exactly where the rubber hose that starts at the top of the oil cooler (in your photo above) is routed?
Did your '99 motor have a metal nipple protruding from the top of the oil pump housing at the front of the engine, and was there a hose that ran from that nipple towards the rear of the engine, to the coolant reservoir or to a Tee with a connection from the hose that comes from the oil cooler and then goes to the coolant reservoir?
The reason I am asking is because a previous owner of my '98 engined Boxster just plugged the top of the oil cooler with a short piece of rubber hose and clamped in a bolt to seal it off. I haven't been able to find the correct routing of that hose from the top of the oil cooler.
Regards, Maurice.
schoir is offline   Reply With Quote
