Thread
3.4L Motor Swap Underway!
11-30-2010, 08:41 AM
5
insite
so, the engine is in the car. i popped it in & installed the clutch & LWFW and a new RMS.
i rotated up the resonance tube to get the valve as high as possible. this is REQUIRED to make room for the air conditioning lines. it was a total pain in the a$$ to get the AC compressor back in. that, and it's making a little noise now, like it's not aligned properly.....
i popped the tranny in:
along with some new transmission mounts from a 993 w/ some spacers installed to lower the transmission:
i had THREE issues with the transmission mounts. first, i tried to use 1" spacers; they don't fit on the trans mounts. then, i cut them to 5/8". everything SEEMED fine, except the stud protrusions from the motor mounts were a little long; they hit the subframe:
i cut off the studs below the nut. again, everything seemed fine. when i went to install the big crossmember that connects the subframes, it hit the transmission. looks like i'll need to cut antother 1/4" from the spacers. this will put them at 3/8".
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite
Find More Posts by insite
