Old 11-30-2010, 07:33 AM   #1
schoir
Originally Posted by Sain0rs
I managed to crack the lower breather line coming off my Air/Oil separater in my 2003 986s. (the plastic accordion style hose that comes off the lower port on the right side of the AOS when standing at the back of the car looking towards the front). I did a homemade glue+tape job on the hose but I don't think it's a good permanant fix.
I actually cracked the upper plastic hose last year but that one was easy to replace. Anyone know the technical name for the hose coming off the bottom right port and where the other end of it goes? I tried looking on pelicanparts and in my bentley manual but I can't find any info. Looking in the engine bay is making me wonder if this is a "drop the engine" professional kind of repair job..
Any help is greatly appreciated
For a 2003, the part number is 996.107.147.58.
Porsche calls that part a "crankcase breather hose".
Also, did you crack the actual hose or just the flexible circular connector on the end?
If that's what you cracked, you can replace just the end by swapping it from the end of a new part.
Regards, Maurice.
schoir is offline   Reply With Quote
