The company that holds you warranty will do everything possible to void the warranty should you actually need it.
Whether or not the component works or not, it is not recognized by Porsche and therefore is deemed junk that will void the warranty.
I did the test work and development of the LN SPOFA unit, they are standard equipment on ALL my engines which cost more and are more developed than the factory engine.
If the engine is under warranty you are going to have enough of a fight getting it covered should something occur, even if you don't have any "questionable" components installed.. I'd never install the SPOFA on an engine under warranty. I do my best to avoid cars with any warranty in effect.
(I have ZERO respect for warranties)
You can have fun with the car/ engine when its out of warranty.. Until then you'll be fighting with some clown sitting in a cubicle, wearing a polyester suit who doesn't know ANYTHING about your engine when you have an issue and its his job to ensure that your claim doesn't get "authorized"..
US Patent 8,992,089 &
US Patent 9,416,697
