Old 11-12-2010, 10:45 AM   #2
Lobo1186
If you have made it this far then you are doing well. If the pics are not enough go to this link Zackwatt's DIY I will continue to speed through these parts.
Next you will see the whole seat-belt kit-n-caboodle right in front of you. It should look like this:
Note the wire. If you see this wire DO NOT DISCONNECT IT!!!! first you must disconnect your battery.
now for the fun part. There are Three anchor points on the whole assembly:
1) Floor Anchor, Using a flat-head screwdriver, simply pry off the cap and you will see a 17mm Bolt, LOOSEN or REMOVE it does not matter.
2) At the pinnacle of the seat-belt behind the headrest there is a pulley type part. Pop open the cover and you will see a 17MM bolt, LOOSEN SLIGHTLY
3) On the seat-belt spindle there is a bolt towards the bottom of the assembly on the outside it is 17MM, LOOSEN most of the way.
After this we will go into how you will complete the swap over.
