Originally Posted by fu03steve
i have a 2.7
 dont hit me
but im only removing the secondary cat
Adam said it should be fine...
as long my main cat is on...
is that true or no?
im confused...
answer with yes or no!!!
make my life easier
I have an '02 2.7 with the secondary cats removed. There is NO cel light and it passes emissions without a problem. I surmise a slight performance increase because of the weight savings rather than freer flowing exhaust. Also it traps less heat in the exhaust system. Two little furnaces rather than four. Just my opinion.
AKL
'02, Arctic Silver/Graphite Gray, 2.7, TIP, 2nd cat delete, Charlie Chan muffler,de-ambered, Braille Battery, clear tailights, painted bumperettes, clear third brake light, M030 sway bars, F shock tower braces, clear rear deck, '03 side vents.  15mm spacers fore & aft.
