Old 09-28-2010, 01:13 PM   #5
eightsandaces
Originally Posted by SeanZ4
I had the same loud creaking noise coming from my clutch a year or so ago. I followed Steve Tinker's posts and removed the slave and greased the tip of the little plunger thing. It was an absolute nightmare to get to and remove and replace. I leaked hydro fluid all over the slave area. I bled it off a couple of times and finally got everything back to normal. The clutch was completely quiet and smooth two or three times then creeeeeeeak... it started up with the noise again. I've been driving it a year or so with the noise. It shifts fine but the creaking drives me nuts. Someone told me that it may be a dried out guide tube?? My car is 10 years old and only has 39k on it so????
sean
Could be the pedal assembly too, mine squeaks but you cant hear it when it's running.
eightsandaces is offline   Reply With Quote
