Old 09-28-2010, 12:33 PM   #3
insite
is there an actual problem with your IMS?
there are retrofit kits available from LN engineering. they are much better than stock & can be installed with the engine in the car.
that having been said, the kits are quite expensive, and the labor involves removing the transmission, clutch & flywheel. $2,000 for the job sounds fair.
i would combine this with a clutch & rear main seal, since all require removal of the transmission.
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
