Originally Posted by blue2000s
Can you use an aftermarket ECU? Motec can run a throttle by wire engine with variable valve timing. Not sure if anything special is needed for the high pressure fuel rail.
I would think Motec could do this, but would require quite a bit of tuning to make it work right.
I just don't see why you'd want to do this swap....
