Old 09-14-2010, 05:30 AM   #5
blue2000s
Porscheectomy
Originally Posted by Cloudsurfer
In two words: Good luck. The new A96 cars are running Siemens management, not Bosch as all previous cars did. The engine management is COMPLETELY different. I can't even begin to imagine how much of a 9X7-2 car's electronics you would need to make this work.
Can you use an aftermarket ECU? Motec can run a throttle by wire engine with variable valve timing. Not sure if anything special is needed for the high pressure fuel rail.
