Originally Posted by chaudanova
what was the inner diameter of the 996 and 540i Maf housing? Can you tell me the OD also?
Would there be any advantage to using a 996/540i larger housing with the regular 986 maf sensor if connected to a cone filter on one end, and, for my current setup to a larger 3" through hose/pipe with 75mm TB and IPD plenum?
cloudsurfer is right; your air fuel ratio will be miscalculated if you run the incorrect MAF housing diameter.
if you are just looking for a flanged MAF housing with which to make a cold air setup, the MAF from the E39 BMW 535i (the V6) has the same inner diameter as the boxsters.
