Old 09-06-2010, 02:35 PM   #2
autodoctor911
if you look closely, although the overall hieght is fairly significant, remember it is only 20 inches long, and also look how high the crankshaft centerline is. a large portion of that height is below the centerline, which would be a ground clearance issue, more than anything. not a big deal, unless you have lowered your boxster significantly, or like to haul ass over speed bumps. but a dry sump oiling system with a large capacity, may be in order anyways to increase cornering ability without starvation, as well as increasing ground clearance, and just to increase oil capacity.
autodoctor911 is offline   Reply With Quote
