Old 08-28-2010, 06:43 PM   #10
schoir
Originally Posted by jaykay
Thanks Maurice!
No salt on this car so at least that will help. Hopefully no special tools are needed. I intend on having the muffler in place first (putting in a new one) and then fitting the pipes.....I am using ramps so I am bit ify on being able to all the access I need. Does one need to remove the rear bumper cover to get the muffler in and out?
New clamps definitely make the reassembly easier and helps insure easier disassembly next time.
I used all stainless nuts,bolts and washers at the joints between the headers and cats and muffler. Marylandmetrics.com carries all metric hardware you could ever wish for.
As long as your ramps are high enough to let you move your elbows freely across your chest and you can turn on your side, you should be able to do the job comfortably.
Regards, Maurice.
schoir is offline   Reply With Quote
