Old 08-25-2010, 06:45 PM   #5
schoir
Originally Posted by jaykay
Does anyone have a good set of instructions for installing the fabspeeds as well as taking the muffler in and out (mods afoot!)?
I am hoping I dont need a torch to heat up crusty bolts....and wondering if I need to leave the muffler in..
jaykay:
If your Boxster has been exposed to a few winters with road salt, etc. (Toronto?), then there is a more than 50/50 chance that you will have some difficulty with at least a few of the twelve bolts that collectively hold the exhaust manifolds in place.
PB Blaster, WD-40, etc. help, but are not a solution in some cases, even if you apply it religiously every couple of days for a few weeks (as I did).
Applying heat with a torch, or, preferably an inductive heat electric tool gives you the best odds of not snapping off any of the bolts.
Take a look at this thread for details on what it took on a '97 Boxster with 22K miles on it a few months ago, without the car having been driven in New York winters when there was snow on the ground:
http://www.ppbb.com/phorum/read.php?19,1552140,1552140#msg-1552140
Good luck, and keep us posted with your results.
Regards, Maurice.
schoir is offline   Reply With Quote
