				Still Vexed
			I misspoke, I do have the litronic xenon. Both goon news and bad. I replaced the headlight switch last week with a genuine porsche part so I dont believe that is the issue... but you never know. I read through the manual and dont seem to have seperate headlight relays.
I removed the drivers headlight assembly and checked all the connections to be sure that everything checked out, it did.
I am hoping that the bulb doesn't need to be swapped out and have confidence that is not the issue as the bulb goes off but then can be relight with a flick of the headlight switch.
I am going to swap the left and right bulb and see if the issue continues with the bulb in question. I will keep everyone updated after the weekend.
Thank you all for the ideas and assistance.
				2003 Boxster S - sports touring - triple black
