Originally Posted by KeithB1
If not and your Key will. I would guess the door lock mechanism is un-plugged inside the door. I also had red light on the dash and the horn beeped once if I used the remote.
Keith, if I try to lock the door using either the key fob or the dash button it won't lock. Something is telling the locking controller (unless it's bad) that the door isn't closed or one of the door handle micro switches is telling it that the handle is being pulled. I have a feeling I'm going to have to pull off the door cover and do some closer visual inspection...
