Old 08-05-2010, 04:24 PM   #4
986_Ron
Originally Posted by sb01box
you may want to start here before taking the door panel off
http://www.ppbb.com/phorum/read.php?19,1565400,1565407
this tests the micro switch in the door mechanism by the latch
search using "window"you'll get tons of thread with door/window discussion
good luck
Thanks, that link helps a lot. I'm going to have to replace the regulator on the passenger side. I figure I'll order everything I need at once. My car has over 100k and little repair stuff like this is starting to pop up.
2000 Boxster.
1997 Carrera 993.
986_Ron is offline   Reply With Quote
