Old 07-16-2010, 06:41 AM   #2
tonycarreon
tonycarreon's Avatar
so how far does it go?
- you lock the door and the doors (lids, etc) latch
- the lights flash twice ( indicating the car is locked )
- no horn sound ( the horn doesn't sound when the alarm activates unless something is "open" )
fyi - if you have the top down and lock the car without a red clip, the sensors are deactivated so you will be able to reach into the car, etc. without tripping the alarm.
also the manual indicates that if there is a problem with the alarm system, the horn will beep twice...
found the fuse layout for the 99...
