Old 07-14-2010, 09:36 AM   #21
schoir
Originally Posted by 97 Boxster
Do you have to take the glass and regulator off as well to access this lock?
No need to take either the glass or the regulator out to access the lock assembly containing the microswitch. You just have to get the window in the correct position for easy access.
One caution: Unless you have access to a PST2, PIWIS or Durametric be careful not to set off the airbag light when the door is apart and the door airbag is disconnected. '97's normally don't have a side airbag, but perhaps if yours is a late build, etc...
Regards, Maurice.
schoir is offline   Reply With Quote
