Old 07-07-2010, 06:45 AM   #1
james214
Another top Story
For what it's worth, I had the same symptoms: handbrake light works, top fully down, no response from the motor when pressing the top up switch. Tried the "turn key on to fool the computer" to test the handbrake switch, then tested switches via the relay socket. Everything checked out OK. gave up, put pieces back together, tried once more and worked perfectly, up & down and stop in the middle to replace the countersprings. My guess is corrosion on a relay tab. Any one else have an idea? Have no confidence that I actually fixed the problem--probably just delayed the real troubleshooting and repair.
james214 is offline   Reply With Quote
