Old 06-30-2010, 07:37 AM   #10
schoir
Originally Posted by TimAustinW
I had this issue this morning. Checked fuses. Almost put in an order for a new top relay and decided to check the forums first. So I went out and sure enough the parking brake light was not coming on so I just smacked the parking brake and the light came on, top came up. So is this a micro switch for the parking brake? Anyone have the part number for that? Any idea on install difficulty?
Thanks,
Tim
:troll:
Tim:
On a 986, the part number for the parking brake switch is 996.613.112.01 (lists for about $5.00).
DIY install difficulty varies: you either have to remove the center console, which then makes the removal and replacement of the switch very easy, or you can try spraying some electrical contact cleaner in the direction of the switch from the little access panel on the driver's side of the console, at the rear.
Regards, Maurice.
schoir is offline   Reply With Quote
