Thread: 997 Ssk
Old 06-15-2010, 06:54 AM   #2
Burg Boxster
green bracket on top is the alignment tool for realigning the shifter cables if necessary. If you mark them when disconnecting the OEM shifter, you'll be fine and won't need the alignment tool at all. That being said, either w/ or w/o alignment tool, before you reinstall the console I suggest taking the car for a quick ride to test all gears.
Install directions here
Skip the portions you need if you have the whole assembly. Pictures are mostly from 9x7 but very similar for 9x6.
