Old 06-04-2010, 05:31 AM   #1
JFP in PA
Originally Posted by lenoxx
I just put a used tiptronic transmission in my 2000 boxster (2.7) but the axles wont bolt to the flange shaft (at the transmission). I think the transmisison was from a 3.2 Boxster S. I called the dealer and they said that there are two different part numbers for the Flange Shaft (2.7 vs 3.2)
Flange Shaft #15
Has anyone experienced this? Can I replace both existing 2.7 axles with Boxster S axles? Any recommendations?
The axels, flanges, brakes, and suspension carrier hubs are different on the S, which is why rear S brakes cannot be bolted onto a base car. You need to either switch the flanges on the Tip, or get ready to spend a lot of money to convert the rear of the car over to an S configuration; a waste of money in my opinion…..
