Old 06-01-2010, 01:38 PM   #18
insite
Originally Posted by mdex
I never have issues with front end grip, it is mostly about balancing it with the rear with my set up so getting more front end grip isn't normally my concern. I tried running larger tires up front (actually due to stock sizing not being available in time for the next track day) and the extra grip in the front slowed things down as I wasn't able to get on the gas as early coming out of high speed corners.
What tires / sizes are you running?
I find that a 26psi to 28psi cold temp all the way around gives a dead neutral car on most "R" tires with my setup. I guess alignment and other issues have a big part in our tire pressure balance front to rear and car to car.
mdex - keep in mind you're running r-comp & the OP is running street tires. also, his car is stock. if you're on r-comp, i'm guessing you have a few other bits installed that help neutralize the handling.
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
